outlaw
Castle addicted
outlaw's Avatar
06.27.2011, 04:36 AM
If you want to run the 1409 in a 1/8 buggy-based chassis consider getting a lower kv and running something like 6S 2200-2600mah. It will help keep the current draw low and keep the temps down on the smaller motor. If you want to run 4S consider the Castle-Neu 1415 2400kv and MMP combo. You can dial back the power with torque and/or punch control if needed.
Well the 1415 does have way too much power
I'm not going to 6S
I want a motor around 1000 Watt
I will give the 1409 a try
kind regards
Mirko
Brushless motors have to be green ....
