thzero
06.30.2011, 12:00 PM
Yes, I'm pretty sure you hit on the head. Be interesting to see if beefy sleeves solves the problem; if it does, certainly a less of a hassle solution.
Originally Posted by NickRummy View Post
I have a sleeve I'm going to try first. You know how on the adapters I made for you there is a shoulder in between the 24mm hex and the bearing in the knuckle? I think that's why the XL axles have a problem. They have nothing to support them when they flex and the weakest point is at the thread where they are tightened down. I'm going to make some of these beefy sleeves and try them out and see how it holds up.
