Aussie Nerd
07.10.2011, 05:23 AM
The second update is some work on the front axle. I got my cheap as chips venom AX10 C hubs and immediately noticed quite a bit of material could be removed from the back of the C hub (around 2-3mm) without cutting into the mounting bolt slot. So into the vice it went. The next part was lathing the tubes so that I could use HR length super 300s. I originally only lathed up to the original link mount width as seen in the first picture. However this didn't make the most of the extra engagement afforded by the 300s so I took a little off the link mount as seen in the send picture. The end result is about +-10mm narrower a side. Plenty of room to go from a 350-475 to a 600-725.
Right now the tubes are pretty much done minus drilling and tapping, so I might try get to a roller of sorts tomorrow.
Kieren
