Manne
07.13.2011, 06:15 AM
Update:
Long time no see, but now Iīm here!
It has been tons of flux driving, alot of 1:1 car tuning and just too much work to get a chance to update, and my camera is "stolen" so I can only give you crappy phone pics= No action shots or macroshots...
Anyway, this is the case.
The car have been great so far except the gearbox housing breaking due to too much chassi flex, so I bought a tcs crawlers chassis.
But I didnīt feel comfortable with just 5mm....So I sandwitshed the stock chassi and the tcs chassi for 7.5mm on each side, totally 15mm thick chassis! No chassis bending on my truck:
I also made a new, thicker motor mount:
After I fixed that I got some major air in the sandpit, and the only thing I managed to break was shock shafts...An endless amount of shock shafts!
So, It was back to the workbench, and here is the result:
Revo 5mm pushrods:
I started to remove everything from the shock body, and then I mounted the end cap that holds the orings and drilled up the holes in the cap and the body to fit the new shaft:
I drilled up the piston:
I mounted all the necessary parts on the shock shaft and then pushed the shaft inside the shockbody:
And this is how I mounted the piston in a safe way:
metal shim:
