D8T motor mount/center diff mount
nastety92
D8T motor mount/center diff mount - 07.15.2011, 08:20 PM
So I've been having a problem with my motor/center diff mount on my D8T.
My aluminum motor mount is slightly lower than the other side of the center diff mount, the plastic mount more towards the front of the truck.
What should I use to space the motor/center diff mount properly? I looks to be roughly 1/4-1/2". I had a smaller spacer in there before but it caused one of the screws to get loose and that caused mount to get loose and the pinion gear to strip.
Did the kit come with a spacer that I was suppose to install and maybe I just lost it?
Thanks for the help,
Nick
Tamiya TRF801Xt-e
