Overdriven
Destroyer of Tires
Overdriven's Avatar
07.26.2011, 12:00 AM
Originally Posted by whitrzac View Post
your over-thinking this... most .21\.28\etc motors use the same height/size/etc of mounting hoels. Get a motor to attach to those and your golden.
Making an e-mount that bolted onto the nitro engine mounts would make things alot less complicated. But it would also raise the motor up quite a bit more than other more traditional e-conversion mounts. I'm pretty sure a 15xx motor is bigger in diameter than a big block nitro motor and would never sit between the mounts like the nitro. Not that this is a concern for everyone, especially budget minded folk.
How about modding the flux motor clamps to make it work? ie; make up a bottom plate for it with countersunk screws going into the motor mount. Drill and tap some holes in the bottom plate to match the existing nitro holes.
That's the Fine Design solution to motor mounting. Problem is you need different diameter clamps for different diameter motors. Not always a problem, but it can be, especially if you're looking for a bolt on (no dremel) solution to every application. Which seems to be what the OP was suggesting.
