Great work
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Great work - 07.26.2011, 03:30 PM
I really enjoyed your machine work and fabrication process, but your drivetrain design seems a bit over complicated for my taste. When you compare what you have done on your project, to the readily available and hugely simplified hubs that are on the open market I doubt many people would want to go in this direction. I to think you are going to have a lot of issues with chain problems, and getting your electronics setup properly in order to get this E-bike working to a level that you will enjoy riding it. Still your machine work is pretty cool, and it appears that you can do just about anything to fabricate a workable solution. Not sure what this setup has cost you, but when you can purchase a chinese hub kit for under $500 and easily convert a montain bike in one day to a powered 25mph vehicle other options are likely to fall short. The major cost in any E-bike project is the battery setup, which one can spend anywhere from $500 to $2000 depending on what type and voltage one wants to use, and how fast they want to go. As long as you enjoy your work that is the main thing. Have fun and I always lean towards what I learned in my younger days, which is KISS. "Keep It Simple Sir".
SUPERMAXX YOUR LIFE.
