EDS
08.06.2011, 01:40 AM
Another small update today. I got the rear chassis braces designed, cut, and mounted just as I had wanted to. I bent the rear skid-plate up dramatically to increase the ground clearance. I then cut the skid-plate and bolted the other end to the brace. The pieces aren't the best looking because in order for the lexan and aluminum to be flush I had to file the aluminum while the lexan was mounted. It doesn't matter though since the lexan parts will be covered by the Tvp's
Here's a of pictures of the rear chassis braces.
The front and rear clips in there respected positions..
The picture makes the truck look pretty short but in reality I am shooting for a wheelbase around 12 inches. Considering that the Stampede 4x4 has a wheelbase of 10.83 in. I believe that 12 inches should be perfect.
I'm currently designing the TVP's as we speak. I'm not sure when I will be able to work on them but it should be in the next few days.
Stay tuned..once I get the TVP's done..this thing will really start to come together quickly.
