Semi Pro
Semi Pro's Avatar
08.14.2011, 10:53 PM
Good luck having the diffs hold up! The diffs are worse than the full size revos, I was blowing apart diffs on 2s after a few runs and on 3s I was lucky to have a diff last for more than an hour
my diffs held up fine to the cm36 7700 on 3cell lipo and mikey84's diffs are holding up fine to the cm36 9000kv on 3cell so i think it really depends on the way you set up your diffs and how you drive it.
i
