EDS
08.26.2011, 02:53 PM
I got the motor mounted today. I mounted it with a RC8e motor mount. Like I said before this motor fits perfectly! Adjusting gear mesh will obviously be a pain in the butt but it won't be to bad since I have a L - shaped allen key that I trimmed to get into that space. My only concern with this set-up is that the slots on the motor mount are vertical...so I can just imagine going off a big jump having a hard landing and the motor sliding down on the motor mount since its so heavy, so I'm trying to figure out a way to support it from underneath so that doesn't happen. But other than that it fits perfectly and the black can will fit in one I cover the aluminum in flat black vinyl.
Next I have to work on the drive line. Does anybody have a suggestion for diff fluid for the front/center/rear diffs?
