2genewb
Go Phils!
2genewb's Avatar
08.28.2011, 09:00 PM
well brian, if you lose the battle with the wife, those knifes i posted will go clean through an entire turkey bones and all in one chopping motion if you put a little force behind it. as we all know, cutting off a safety off and loading a clip puts you at a major disadvantage when the would be robber is already locked and loaded. also... lunging in a hallway could put you clean through the perpetrator given the weight and point on those knifes. a bat can't do that.
you could still keep a gun safe across the room or a small one under the bed for added security. the knifes would just bridge the gap between those possible critical moments. perp downstairs... get the gun. perp in the room... grab and swing high. :D having the extra option may just give you that leverage with the wife as well. you could possibly convince her that this way the guns will stay put away.
