BIG-block
09.15.2011, 11:32 PM
Originally Posted by NickRummy View Post
Finally got around to fitting the hub on! Hub on the XL axle with pin through both.
O-ring on the hub to hold pin in place and then with the wheel mounted.
Gave the machinist the go ahead on producing more so I'm getting anxious to see a full set in use!
Looks very impressive to say the least. Well done. How hard was the HPI stub axle to drill? Did you have to use a special bit to do the job? Last question. Would you consider making the same thing but in 17mm version for us that are still running 1/8th size? Would be very nice if you did it with similar off set as the stock XL setup has.
