09.20.2011, 03:31 PM
As the panda pointed out, the modules are paralleled through the balance leads with a 6 to 1 adapter for balance charging as a complete unit/module. I could have permanently connected the balance leads, but disassembly would then be more difficult. Also, if a cell within one pack happens to go south, it would try to equalize with the other cells in the other packs through the small balance wire, which might be problematic! The way the modules are built, everything is...well...modular - and easy to remove/replace in the event of a problem(which hopefully never happens).
The Stealth bikes look cool, but I am not a fan of the hub motor concept(unsprung, rotating mass that also has a gyroscopic effect) - and they are quite expensive as well. It is also a lot closer to a bicycle than a motorbike IMO - they are a very heavy bicycle. A frame that accepts readily available parts is more my speed for sure - at least 65mph top speed and a 20-30 mile or so range would make for a nice commuter and/or play toy, too. I have considered making a 2 speed tranny as well - one speed for trails, etc., and a taller gear for the street commute. The range will only get better as battery technology moves forward, too. It only takes time and money to make it happen(and I have neither in abundance). :)
