crazyjr
crazyjr's Avatar
09.21.2011, 06:59 PM
Are you plaanning two esc's? not sure if One to two motors can be done proper. I think you are running both not enough esc and too much battery. Why not slpit the battery and run two esc's? or split the battery and series it to a bigger, stronger esc and better motor for this application? If it were me, I'd split the battery and make a 12s 10,400mah , at least a 200 amp esc (12s capable) and either a plettenberg bolido or a lehner 3080 motor
