Thread: 5mm connectors
5mm connectors
HotnCold
HotnCold's Avatar
5mm connectors - 03.26.2006, 09:45 AM
I was over mikes place last night - putting together some stuff and was wondering - Even with the 5.5mm connectors - the connectors are still not big enough to get both motor wires on. So what is the difference between running the 2 wires to each plug ( besides resistance) - or soldering the 2 wires together extremely close to the speed controller and soldering one wire to the motor. Like this
Motor wire 1 |============( to motor ) Single Wire
Motor wire 2 /
The wires are going to be 3.5 inches long at most. It seems like a connection that was 3.5 would get you the same result in this case ( short connection wires )
Hows that "Hope and Change" working out for Ya???
