Knez
Knez's Avatar
10.17.2011, 01:16 PM
killajb - Ur video is welcomed !
Douwe - Start a build thread
Small update...
My MXL dosent want to be one unit any more...first was moving up and down a bit than i took it off to send it to recall anyway and i see this..
I shipped to castle one MXL and one 1520 motor and bec pro
on 16th of MAY 2011 and stil waiting to receive all items back...
Now i will ship seconf MXL to castle EU. SO lots of $$$ and lots of waiting..
I decided to buy XERUN 150A esc.
What i also want to do is upgrade the shocks with better ones, stronger ones "shocks that can take more abouse"...So i was thinking something like these..
1:5 shocks
Dimensions:
- Overall length, extended: long 155 mm, short 131 mm
- Mounting distance, extended: long 144,5 mm, short 120,5 mm
- Travel: long 43,5 mm, short 30,5 mm
- Inner diameter of spring: 21 mm
- Shock body diameter: 20 mm
- Eye bore: 4.5 mm
- Eye thickness: top 6 mm, bottom 5 mm
- Shaft diameter: 4 mm
- Shaft thread: M4
10mm shorter than stock shocks :/
eye to eye
Or maybe 4x Baja front shocks + wide arms ...
Dimensions (f/r):
Mounting hole distance: 187 mm
Travel: 62 mm
Diameter: 20 mm
6 mm shock shaft
22mm longer than stock
eye to eye
Wish i had room for these brutal shocks LOL!
Dimensions:
Mounting hole distance (extended): 173 mm
Total length (extended): 190 mm
Travel: 56 mm
Shock shaft diameter: 6 mm
Body diameter: 30 mm
http://rc-car-online-shop.de/shop/pu...ad7ca3174a.jpg
Flux 5B CC 1520
1/16 Rally
My Youtube
Russian:Life and Trust is Lost Only Once!
