_dV
10.21.2011, 02:00 AM
I've also used these shocks with the Raven dual rate springs. Very smooth but even though the shaft is 4mm it's not as strong as the stock Flux shock. I bent plenty of those shafts before going back to stock shocks. The other problem is that the plastic caps tend to rip off under pressure, metal caps might help.
