10.22.2011, 12:32 AM
Originally Posted by freddy View Post
nice, do you have any info regarding gearing and runtime?
And do you find the deans sufficant to power it?
again great truck you have there, bet you have invested some time and money to put it together
Gearing is 14/52, with the moabs it is geared for 50mph. I run a 5s 30c 8000mah zippy. Bashing hard it runs 40 minutes.
Deans soldered properly are the only connectors I use, I swear by them. I run them on my e5b.
The only problem I have, even with locker lube in the diff, is that the center diff gets too hot and the lube thins and runs out of the screw holes.
