brian015
brian015's Avatar
10.22.2011, 09:36 AM
Originally Posted by j.f.s View Post
I could buy HPI's E-savage hexes since the flanged nut HPI provides has the support for the rim built in to them.
Yes, those are the type of nuts I was thinking would be used with these - since you are using the threads on the axle to hold the wheel on - instead of other hex designs that hold the hex on with the axle nut and then use another nut (17mm) to hold the wheel on.
So you could just buy the HPI nuts and use them with these hexes, right?
