Knez
Knez's Avatar
10.28.2011, 09:02 PM
Well i am thinking to go 6mm all over the truck this time, as i got xerun, mxl and few motors but not enough 6,5mm connectors :)
Pietrvds - Here infos
Dimensions:
Mounting hole distance (extended): 152 mm
Total length (extended): 170 mm
Travel: 42 mm
Shock shaft diameter: 6 mm
Body diameter: 30 mm
Upper shock hole is M8, i will use 8mm diameter sleve woith inner hole M4...
Hope Alza dosent have too much work these days and this gets cut fast :)
Flux 5B CC 1520
1/16 Rally
My Youtube
Russian:Life and Trust is Lost Only Once!
