10.31.2011, 10:19 PM
I've replaced many antennas on many receivers (never spektrum) and it always worked. I see no reason you can't just solder it back on.
Do you have a separate bind plug along with the 4aa holder? I know earlier spekky units had a bind plug that jumpered two of the three rx pins together. So, if you don't have a separate bind plug I would say that spekky probably did wire the 4aa holder to also do the job of a bind plug.
I'll google bind plug wiring and report back if I find anything...
yes bind plug is separate...so i may just buy a small rx pack to make it work.
I will just try to re-solder the antenna on and see what happens
