cmac
cmac's Avatar
11.05.2011, 11:55 AM
OK. I got the Hitec 7955 servos, and got them installed. The steering is much better, but still under hard acceleration it pulls hard to the left. It is a good amount of torque steer. I noticed when I pulled my UE diff cases apart it says nitro on one side and electric on the other. I assume that you place the ring gear on the electric/nitro side depending on what drives your truck. Could the side that the ring gear is on contribute to the torque steer? If I switch the ring gears to the other side wouldn't it just pull to the opposite side? I have 300,000 wt diff oil in the Slipper 7,000 wt. in the front diff, and 5,000 wt. in the rear diff. Should I go even heavier in the center diff?
