11.12.2011, 02:02 PM
...Any recommendations for offroad bikes? do's, don'ts?
Depends on what you mean by "offroad". Are you gonna do extreme downhill true mountain runs? Or do you want something you can take on grass but mostly will run on smooth trails? In my case, offroad means light flat trails, but mostly paved bike paths. I'm a heavy guy, so I wanted a frame that will withstand the weight plus be able to do the occasional thing like go down shallow stairs and off curbs.
If you plan to do a lot of flat/smooth trail riding, I recommend something where you are sitting more upright (handlebars are a bit higher) or you'll get a crick in your neck.
Go to several shops and hunt around. Ask questions and see which place truly seems like they give a crap. Some will say anything other than what they sell is crap, while a good shop will give you good advice. Tell them what you want and how you plan to use it.
Test drive several bikes and see which feels most comfortable - on the terrain you plan to ride if possible.
Other things:
- Disc brakes: I like them. They are more expensive, but worth it IMO. They don't get gummed up with leaves and crap nearly as much and they feel more linear. If you do get them, make sure they're both on front and back.
- Shocks: Me, I'm old school. My first Trek never had any shocks and it lasted many years. I figure they were just another failure point, but all bikes have them now. Some have them only in front, some both front and back. Make sure the front shocks are BOTH adjustable (a Specialized bike I looked at could only adjust one of the forks). I opted for no rear shocks, but my seat has springs so it's fine for me. Again, I run mostly on smooth surfaces, so it works for me. And for those times where I run on rougher stuff, I just stand on the pedals and let my legs act like shocks.
- Shifters: Decide between grip or thumb. I personally like the thumb-style. Try both on your test drive and see which one suits you. Some shops will swap the shifters out for the kind you like if the bike model you're looking at has the wrong kind stock.
I ended up with a Trek 3700 disc model. Had all the features I wanted, and decent price. It's an entry level bike, but my old Trek was too and it lasted well over 10 years (closer to 15 actually).
