Chainsaw10
11.28.2011, 11:35 AM
Glad to hear your 5s pack fit in there. I was looking for a single 5s that would fit. I have run it with my Hyperion 2 and 3S 45c packs combined to make 5s but I had to strap them to the top of the cover. They are very long batteries. I will order the same turnigy pack as you.
4S is nice alone. 5s is very powerful and fast. I have no need for 6S.
Make sure to loctite the grub screw on the pinion...I even dremeled a small divot in the motor shaft where the screw contacts it.
It is also a must to loctite the set screws that hold the wheel hub pins in place. Use Heat shrink tube to hold the pins in also.
The truck is extremely durable and fun
