RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.27.2006, 06:58 PM
Grant...I must have forgotten to send the drive cups to you. i did intend to include them to avoid this confusion. I sent a set of hardened gears because the listing says the gears are hardened, but the diffs I sent were equipped with standard gears, so I threw in the hardened gear set in case you had any trouble(which you most likely won't). Otherwise, Leroy has provided all the info you should need. I have found that the diff seldom need any shims in the FLM hybrids, actually.
