BIG-block
12.01.2011, 09:31 AM
OK, I was lying. It actually turns out that the internal dimensions are 145-146mm X 49-50mm. Still all the Turnigy 5000mAh 40C and 30C soft packs will fit. Here are some pics of the Turnigy 6S 5000mAh 40C pack in my RC8T.
Can you see over in the right corner where I had to trim a little bit so that it wouldn't press against the battery wires? It's a 10 second job with a hobby knife.
Maybe you can see what I mean in this photo. You can see the black wire is right in the corner and would have been pressing hard against the battery box if I didn't trim it a little.
I hope that helps. Sorry, as I am not the best with a camera but hope that clears up a few things for ya.
What cell count were you thinking of running in your RC8T Ivan? If you are going to run 4S I am certain that Gens Ace 4S 5000 40C hardcase packs will fit too. They are a great battery.
