PBO
RC-Unobtainium
PBO's Avatar
12.01.2011, 04:03 PM
I was referring more to the volume/mass of epoxy being used ie- a smaller quantity spread more thinly would dissapate heat better. When I did my stuff the glue might have been 1/10mm thick between the cf sheets?? The excess was wiped so that might have been 1/2mm.
IDK maybe I've been lucky it hasn't caused me any problems
You're right about heat dissapation but generally speaking epoxy resins don't like being heated - it reduces the strength of the resin
The ideal temp window (generally speaking) is between 10 - 35 celcius...this is for ambient, resin & substrate equally
When you go above or below the resin looses strength
Enhanced Rustler 1515 1.5 MMM
Losi 8ight-T
