Originally Posted by snellemin
I use to live in Ft Lauderdale/Sunrise area. I know the heat. It's nothing compared to Houston summers. I use the 35 shore in dragracing in the hot temps. It's the only advantage you will have in acceleration. If you tore them up, you will need to look at your setup. I never tore mine up.
mabe i ripped them because my rear is spooled
