Thirdgen89GTA
You can sleep in a car, but you can't race a house
Thirdgen89GTA's Avatar
12.22.2011, 02:57 PM
Hey 89gta: I'm a brushless guy. I have a buddy that insisted on putting the biggest motor he could find on his 1/8 buggy. Now he has a surefire .32 in his buggy.
Any recommendations on gearing or other setup advice? It has a 48t spur. I take it from your previous post not to try a 21t clutch bell!
I could happily run with a 17th clutchbell all day long using OFNA blue shoes and OFNA gold springs on a 3 shoe setup. But they would only last about 2 months being about 8, 8hr bash sessions. If I didn't drive the car much they'd last much longer.
Aka, the shoes my buggy has now with its OS 30vg engine are the same shoes its had for the last 3 years and they still hook strong, but they don't look much like the shoes I thought they were anymore.
I did some special prep though. I'd rough the inside of the clutchbell up with some 400grit sand paper to increase the bite. I used ceramic clutch bearings and a vented clutchbell to help town down the heat.
I once temped the clutch bell at almost 315* F before I figured out the gearing, clutch setup and prepwork.
The thing I most went through though was bearings. The clutch bearings would constantly wear out due to the massive heat. The Ceramic bearings were expensive but they lasted a long time so it was worth it.
The buggy is the following:
Jammin X1 FTE
OS 30vg engine bump start version.
Jammin JP-2 pipe
Vented flywheel
17th vented CB
OFNA blue shoes
OFNA gold springs
The above setup was good for hitting 55mph. But it was a gas hog, running wide open in a field resulted in 5 minute fill-ups with a 125cc tank.
  • 1989 Pontiac TransAm GTA, 5.7L LT1/M6 400rwhp+
    • Jammin X1 CRT Pro, MMM/1717, 6S
    • Hyper One Seven 1/7th scale GT car, MMM/1717, 6S
    • Hyper 10TT, MMP/1410, 3S
    • TL Mini 8ight, stock, 2S
  Send a message via AIM to Thirdgen89GTA
