Thirdgen89GTA
You can sleep in a car, but you can't race a house
Thirdgen89GTA's Avatar
01.07.2012, 11:07 AM
I noticed you dremeled out part of the chassis for the spur....another option and what I did under my center diff mount is install some small washers. I needed more clearance for the 1520 CC motor I am running in my mbx5t. Nice job.
In looking at the same pic again, I would definitely add washers under you center diff mount just to bring it up a bit more
Because the X1 uses a 62t spur the CVD angle was unconfortably high. There wasn't any binding, but its already a large angle due to the height of the center diff.
You can almost see the extreme angle of the CVDs in this pic.
http://gallery.me.com/thirdgen89gta/...13257464680001
I didn't take any good pics of the angle. But in order to make it fit I needed to put 4mm of washers under the diff to raise it up enough so the spur didn't contact the chassis.
I wish I had a drill press, or a mill then I could have done it a ton cleaner. But all I had was a dremel and a grinding stone.
  • 1989 Pontiac TransAm GTA, 5.7L LT1/M6 400rwhp+
    • Jammin X1 CRT Pro, MMM/1717, 6S
    • Hyper One Seven 1/7th scale GT car, MMM/1717, 6S
    • Hyper 10TT, MMP/1410, 3S
    • TL Mini 8ight, stock, 2S
  Send a message via AIM to Thirdgen89GTA
