Thread: Country Maxx
Overdriven
Destroyer of Tires
Overdriven's Avatar
01.08.2012, 06:38 PM
On a stock chassis the servo sits in a pocket molded into the chassis. FLM may habe a mount, otherwise you may have to make one. I've seen some people use a RC-Monster battery tray attached to the FLM chassis to secure their lipos better.
Are you going to try and keep the motor up front or turn the trans around so it's in the rear? Looks kinda tight for mounting up front, the servo can be swapped to the other side easy enough, but will the motor hit the bulkheads by the shock tower?
