George16
Supermaxx
George16's Avatar
01.08.2012, 06:57 PM
You don't need to drill holes into the bulks for the setscrews. You can cut a recess towards the end of each hinge pin so you can use the regular e-clip. By the way, get the plastixs through-hardened ejector pins. They are better compared to the regular ejector pins or Ti hinge pins.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
