brian015
brian015's Avatar
01.12.2012, 08:23 PM
I'm going to try the EZRun 150A Pro esc in this build and just wired it up to run two 6s packs in parallel:
I strapped it down with a padded Aluminum strip and Al angles front and back to keep it from moving:
Things planned:
I've been working on cutting down some 23mm hex extenders to give the right width for this build.
I'll add a brace from front to rear bulkheads.
I'll need to make body mounts and then I'm planning to add some lexan undertray pieces to extend out from the chassis and attach to the body.
