01.25.2012, 07:50 PM
Anything is possible, but I literally have 5 runs total on this motor which was purchased new from CC...over the past 6 months I have completely rebuilt my muggy from the ground up off of an IRC chassis, new HD diffs, new drive shafts, new bearings,etc.
However, the cogging I'm seeing feels like the kind with less than optimal batteries...cogs a few feet then kicks in and is ok, or if you roll it and come on the throttle it doesn't cog at all.
I did briefly test my system without a pinion on and the log was perfect without load, so could my motor really be bad??
I have a neu 1521 I could try if I have enough 8mm bullets left....
