Kirkinsb
Brushless All The Way!
Kirkinsb's Avatar
01.25.2012, 08:57 PM
Your numbers are low(especially the Muggy). What sample rate are you logging data at? I have seen 200 amps on a 10 pounds truggy in testing with an average draw of less than 30 amps during the run. A low sample rate will mask the true peaks. Also, any punch control or expo settings on the radio can also lower the recorded peak draw.
I checked the 5t and it was 2 samplings per second. All other settings were stock. No punch control, etc... If you set the sample rate much more than 2 per second, you won't get the entire run into the logging memory....you will only get 7 minutes or 14 minutes. Most guys at the HPI baja Forum are all pulling anywhere from 200 to 240 in their Castle Creations bajas....so, I think that my data is right on the money with it being around 220ish.
My 11lb revo (GPSed at 62mph) is also on 2 samplings per second....and according to the data log pulled a max of 106.5amps. All other settings are stock.
So assuming Castle Bajas pull 230ish...it makes sense to me that a 10lb truck would pull about half the amps as a 28lb truck. Seems just about right to me.
A ten pound muggy pulling 200amps!!!...what the heck motor is in it?!?!?!
All I can say is at a sampling rate of 2/second, all other settings stock, I was pulling 106 in my 11lb revo and 225ish in my 28lb 5t according to the Data log from each mamba XL2.
You have to agree that if he was just blipping the throttle and already getting 240amps...something seems odd when compared to results I have...plus all the other baja owner who have converted to the XL2 and 2028 motor who are getting about 230ish amps as well. That is all I know. a 10 lb muggy pulling 240 amps just blipping the throttle seem high....with the little bit of data logging experience I have had and read about.
Don't know if this helps...I may try a higher sampling rate...but that sucks because I would only get 1/3 or 1/2 the run into memory. Do you think 2/second sampling rate is sufficient?
Was that muggy pulling 200ish using a MambaXL2? let us know.
