brian015
brian015's Avatar
01.26.2012, 05:46 PM
Originally Posted by Kirkinsb View Post
Ok, so my readings at 2/second are probably fairly accurate? And I am not missing any huge amounts of data by not using the 5/second setting? Yes/No? Hmmm, interesting. Is their much benefit to having the data written 5/second as opposed to 2/second since it is averaged? thanks Patrick.
No, your readings are more averaged than if you had the data written at a faster rate - so the real peak of the spike is averaged with lower currents on either side of the peak giving a lower average current written to the memory. Writing data at a faster rate should include less averaged data - so truer to the actual curve.
I think.
