01.28.2012, 12:07 AM
I don't have enough male 8mm bullets to try my 1521 motor, it would be too much trouble to swap them from my 1717.
Any other ideas to test my 1717? I don't have another rig to try it in...I read about the "drill" method on some aircraft sites to make sure that voltage was similar between all leads and check and make sure no lead shorts is in continuity with the motor case.
Also, I ordered some 17mm adapters to put truggy wheels on it to try that if the battery doesn't help.
