magicald
01.29.2012, 09:21 PM
Originally Posted by Kirkinsb View Post
Ok, got a VERY good Hard run with lots of full throttle all the way through the RPM range....best of all, I used the 10 samplings per second setting on my Castle Mamba XL2 with 2028 motor in my baja 5t. I probably ran it harder than usual because I really wanted to see what was the MAX current recorded.....
And it was just about exactly as I suspected. I usual us the 2 samplings per second data setting and pull about 220amps... Now with the setting on 10 samplings per second i got a maximum of 240.6 amps. And i would most likely attribute the extra 20 amps to driving ultra aggressive this run. I was really throwing my 5t around!!!!
I feel my original readings at 2 samplings per second were fairly accurate...seems they were.... I will next run my Revo also with a XL2 that I will put at 10 samplings per second...and see if it is still close to the 2 sampling per second data I have always used.
Thanks for the update...I agree, numbers are not that much different.
I really want to see your Revo data and how it turns out. I'm still waiting on my new Battery, I also got some 17mm hubs to run truggy tires on my muggy as well. I want to see hard numbers as to how much larger/heavier tires really makes on the amp draw with the 1717.
