Kirkinsb
Brushless All The Way!
Kirkinsb's Avatar
01.30.2012, 08:12 PM
Just ran the Brushless Revo with MambaXL2 and 1518 motor. Ran perfect as always...drove the crap out of it as always. I usually collect data at 2 writings per second.. this time I raised it to 10 readings per second and just as I had suspected the data was VERY similar to what I get at 2 per second. My MAX current was 109, Watts was 2128. this is basically the same data...which supports my suspision that I am NOT missing huge chunks of data by using the 2/second writing setting.
Keep in mind before you all blast me...this are my findings...you may get something completely different.
But this all started with a fellow RCer wondering if his 240amp current reading was accurate on his Muggy.....I said it seemed way high compared to my 110amp on my brushless revo. Another member suggested I was missing data not using the highest reading possible....I did not truly feel that I was missing huge chunks. And when I raised it to 10/second....the readings were very close.
Which brings me back to the original topic.....240amps seem really high to me for a Muggy. I ran the crap out of my 12lb revo and could only pull 110ish!!!! Draw your own conclusions....
but I hope this helps out some. Is good data according the Castle's Mamba XL2 data logger....both at 2/second and 10/second.
