Allmost everything was ready from that point, i just had to drill some holes to fit the center diff, battery plate, esc plate....
Then i encountered some probs with my previous center diff so i decided to make another one myself.
I used 10mm thick alu plates, a handsaw and a drill, tapped thread and this is the result, it's pretty Chunky...
offna spider diff with 500k oil.
mounted on the tvp
with the motor
overall view
then the rest was pretty simple, just had to add a battery tray, position the esc recieverbox plate and add the electronics.
