Serum
Serum's Avatar
03.30.2006, 08:46 AM
40-45 mph is the topspeed you might get on 16 cells
you can keep the same gearing and tune your radio down to 60-70 percent. This gives a longer runtime as well.
About the warranter, you act like you are going to ruin it, just run it, use it with sense, gear it with sense and the warranter from BK is good. Much better than from schulze.
The 3-4 day is very quick, i love the service from Castlecreations as well. It is by far the best i know of. They don't have got the mamba maxx out yet, unfortunately.
The XL will eat his way through your diffs and make pritzels from your driveshafts.. on 14 cells, it will hold up a bit. but it will wear out much faster. Unless you are easy on the throttle.
