Originally Posted by cmac
I'm looking to replace my Hakko 936. What are you guys using? I want to upgrade. I still have some difficulty getting the solder to melt quickly. It will not get the solder to melt when touching the underside of a Traxxas connector, it has to be in direct contact with the solder. If I try to touch the tinned wire on top it won't get hot enough to melt the solder on the tinned traxxas connector. My results are, as you can guess mixed at best. I want something that will melt solder with ease.
Make sure your tip is clean. Traxxas connectors are an easy job for that iron.
