Jony Nitro
Jony Nitro's Avatar
02.29.2012, 03:35 PM
Yes, this concept would indeed work(considered it), but would also ultimately result in the mass being located over a wider area(not as centered on the chassis), as balance would pretty much dictate the packs be out on the mud guards(higher Cg as well). With the mass more spread out(and more mass due to extra batt tray and esc mount), the car would be less likely to traction roll(though mass would be higher, which may offset this benefit), but would tend to be slower in its transitional handling(switching directions) - two battery trays would then be needed as well as a new home for the ESC. Ultimately, I think the current setup offers the most positives and the least negatives. It certainly isn't the only way to convert the truck - just the way I chose to do it. They should be on the home page by the weekend. :)
tempted to get a losi for this reason only.
D8T Brushless
Brushless Baja
SC10 Neu Power
