Originally Posted by hemiblas
It only runs cooler on 6S vs 4S when you gear down to compensate. If you take a truck geared for 4S and run it at 6S it will get very hot very fast. Hopefully someone can chime in if they know anything about that buggy. As fastbaja mentioned the 2650 is not rated to run at 6S so you are going to be running very high rpm.
Yeah thats why i need advice on 47/14 in a 1/8 ofna buggy on 6s I only have 6s I have a 51 gear also which gear 47 or 51 will run cooler?14 pinnion
