03.05.2012, 04:25 AM
That said I still always prefer to add an external bec.
Not sure if I just had a sensitive spectrum rx but a mmm couldn't power a 7955tg properly without adding a glitch buster.
Spektrum and castle don't play nice. Castle put out a post about it. The problems are always the spektrum receiver and the solution is the glitch buster.
Originally Posted by BADBOY2 View Post
is 18t pinion good ?if in case i decide to sell the esc ?can i use the 1900kv motor on a 8th scale esc?what other esc have built in bec?
I need to know what spur gear you are using to suggest a pinion size. Yes you can use the motor on another esc. Every car (not plane or heli) esc I know has a built in bec.
Nearly all ESC's have a BEC... the rating is determined by how it is made... it cannot be raised (just buy ESC with higher rated BEC).
Times have changed! I know the MMP and XL2 esc's have an adjustable bec via the castle link. I believe the MMM with the newest firmware is also adjustable? I'm not sure on the MMM, but I do know Castle can adjust the MMM's bec while at their facility. Adjustable voltage, fixed amperage.
