cmac
cmac's Avatar
03.07.2012, 10:33 AM
Originally Posted by MAYHEM6969 View Post
Ive got mine all shimmed out thanks to neil they feel good now the problem i have is the cvd"s keep popping out with the suspension dropped all the way down do i use the extended erevo cups or the hpi cups i looked at there dimensions and the stocks are 17mm long and the extended ones are 19mm long will 2mm make that much difference?
Just give them a try. If they are a little long then you can hit them with bench grinder. In my build there were a lot of little things that I had to grind or file to get them to fit.
