03.10.2012, 03:05 PM
Thank you both. Do either of you happen to know the mounting pattern/screw hole dimensions Of the 1717. I'm sure I can make it work if need be, I might have to get a new motor mount but that's about it.
The 1527 is a higher rpm motor though correct? That would be a plus I'm sure.
