03.10.2012, 04:11 PM
The bulks reamed to 4mm sounds pretty interesting. I wonder if FLM would be interested in making some arms and bulks with hinge pins for that? But probably not.
Anyway I have believe Mugen 6t drive shafts will work on the Maxx. Particularly on RPM truetracs. The only adjustment I see is that the outside bearing slot needs to be reamed 1mm to allow 16mm bearings.
Can someone please measure their Mugen 6t shafts for me?... From the ball part of the shaft to the pin part? Not including the stub axle part.
