IrishChamp
03.10.2012, 08:00 PM
What esc did you use, ice160 or similar? Also, what mah were your batteries, 10s would most likely push my truck to over 20lbs with 5000mah batteries.
I think mechanical braking would be straight forward but I think I might miss reverse a little, I could live without it though I'm sure.
I have a heavy truck that I used 10S and also up to 60V on and it was a blast. I would suggest 10S or higher with a low Kv motor.
