Look at the watts!
bdebde
That's All Folks!
bdebde's Avatar
Look at the watts! - 03.12.2012, 10:11 PM
I switched to i-chargers a couple years ago, at the time they had the highest watt output per dollar. They are great chargers. The higher end (and newer) models have closer balancing tolerance.
Bottom line; always check the watts of the chargers you are comparing... a lot of cells and a lot of amps do no good if the watts are low.
